Intercooler pipe with stock elbow
Will I notice a benefit with a aftermarket intetcooler cold pipe with the stock elbow on.
Sent from the can! |
Have you done the EGR delete? If so I would think you would gain more by changing out the elbow, as there are a lot of restrictions in it. I personally can't say what the gain would be on the cold pipe, but it doesnt look nearly as restrictive as the elbow with EGR valve and other stuff in it.
Elbow is restricted aswell!! But ^^^what he said, your best bet is the elbow and pipe for full benefit!!!
I was told to stay away from the aftermarkter elbows by Diesel performance in WI. Because the aftermarkter elbows lean out the drivers side of the motor. Im new to the powerstorke world.
, there is an issue with flow in the intake , that restricts aswell and can see issues with heat towards the back of the motor , due to restrictions in intake air flow is limited and flow does not make it all the way to the back of the motor , hope this helps a bit
I doubt it, minimal if anything (temp wise)
Here's a side x side of oem + mbrp
I swapped mine out, didn't notice any real difference, maby 10-20F lower on the egts but its hard to tell, could just be the placebo effect. I saw a much bigger difference in my egt's when I installed the 4" DP, consistently 80-100F less. No real change in throttle response, smoke etc etc for either.
I agree with above. I cant imagine an aftermarket elbow limiting flow to the drivers side. If anything the intake manifold is the restriction and the back cylinders are receiving limited airflow.
Flo-Pro IC Pipe MBRP IC Pipe |
