EGR Delete questions. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-26-2012, 09:23 PM Thread Starter
I just did alot of work on my 08 6.4l. I ran a H&S XRT Pro, with a full 4" turbo back exhaust with a dpf and cat delete running into a 5" tip with a AFE stage 2 intake. I want to put in a sinister EGR delete with a high flow intake elbow.
When I do this can I remove the two coolers to shave some weight and space in the motor? or should I just leave the coolers in. Also what advantages does an EGR delete have aside from not using the coolers?
Thanks,
-David
DavidMcComb is offline
post #2 of 7 Old 10-26-2012, 09:38 PM
superduty6.4's Avatar
Thanks,
-David
You can remove the coolers and if you purchase a kit with the elbow then you can remove the bulky stock elbow and install the smaller, more smooth flowing aftermarket elbow. Another benefit aside from coolant not flowing through the coolers is no more hot, sooty exhaust gasses going back into your intake manifold.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 7 Old 10-26-2012, 09:54 PM Thread Starter
Perfect that what I like to hear. is removing the EGR cooler hard? I would lke to do the EGR delete, elbow, and cooler removal myself. I know they are pretty bulky so im guessing this means cab removal?
post #4 of 7 Old 10-26-2012, 09:59 PM
No cab removal, just patience. Times vary from 4 hours for guys who don't deal with seized bolts and other little issues to other guys who say 8 hours. I guess if a person plans on a day then you would be safe. Kind of alot of time if it takes 8 hours but definitely worth it in the end.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #5 of 7 Old 10-27-2012, 06:27 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
I would plan on a day also. I think it ended up taking me close to 8. I had some issues with bolts and clearance getting the horizontal out, but it wasn't terrible. I would suggest trying to bribe a friend or 2 to help.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #6 of 7 Old 10-27-2012, 06:54 AM
blackcloud2k's Avatar
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
Having a second set of hands when removing the coolers is key. It goes alot quicker with one person pushing and the other pulling. it isnt hard and It can be done with simple hand tools just takes a little patience. Like was said plan for a day.
2015 F350 Ruby Red Platinum, SRW CCLB, Color matched Ranchhands, rigids.
SOLD:
blackcloud2k is offline
post #7 of 7 Old 10-27-2012, 07:04 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
have a helper just to keep your sanity. also i would start by taking off the drivers wheel and inner wheel well liner to remove the lower part first and see if the lower part bolts are seized. have plenty of small ratchets and those ratchets they make with screw driver handles would work really nice on some. make sure to lube the O rings on the plugs so they will slide in easy and seat properly.
search for this and there is a nice write up on the install. it helped me out
Big_Smokey is offline
