Egr delete new coolant Y
Going to try to tackle my egr delete and was wondering of anyone knew the part number to the plastic coolant Y that everyone says is so brittle and breaks, I'd like to have one just in case, thanks!
Just remove it and you should have no problem. You will need to re-install, but while you are wrestling the coolers and brackets out you will want it out of the way.
No that's not it, I've seen it called the return T
If you remove the egr coolers and valve I don't thing you need it.
I've just heard its brittle and easy to break so I wanted to have one on hand
I am wondering the same. Why does it need to be re-installed and what connects to it? I have a couple of sets of directions but near the end it just says reinstall coolant y but I don't get o picture of what it goes to.
