4.5" lift on buy 35" or 37" tires???
I have a 4.5" lift an wondering what looks better 35" tires or 37" if they would even fit
Sent from my iPhone using AG Free |
I am a power freak but at the same time i do like a "full" wheel well. last time i lifted a vehicle i felt it robbed my power to much with the bigger tires. so depending on if your POWER or LOOKS person decide based off of that i personally being power i would go 35's and it shouldnt look to bad since you stayed with a smaller lift.
tire size will depend on wheel size. If you run a 9" wide wheel with 0 or a + offset you can fit 37's if you run a 10" wide will with a -offset 35's is all your going to get on and keep from rubbing. Running a wide wheel with a neg offset helps to make up for the look of no having a taller tire. this is a pic of my truck with 35's on 20x9 with 0mm offset wheels on a 4.5 icon.
I'm running 35's with NO lift. The 37s will be right, 35s too small with a 4.5"
With that being said....wheels specs are the ultimate factor in what tires will fit and what tires won't. A 20x10 (or wider) with crazy negative offset is going to hurt your chances of fitting bigger tires with less lift. My wheels are -19mm offset (pretty sure) and they work well. I know a few guys pulling off 35's at stock height with -24mm offset 20x10's.....but they are REALLY pushing it. Moral of the story.....get the right wheel, and you can pull 37's off. |
My truck has a 4.5" lift with 325/60/20s (35.5" tall tires). I prefer more clearance and do not care the stuffed look.
![]() I hear that. Might not be a bad idea. |
heres mine i just put a 4.5" icon. i like a 35 with that lift if you get a wheel that sticks out a little.
I was looking at keeping the stock wheels but I think 12.50 is all the wider I can go with the stock wheel or would 13.50 be fine? Also I have herd that hub centric wheel spacers are good to use as well I personally like the stock rims better than most aftermarket
