What should I do next - Ford Powerstroke Diesel Forum
Old 10-16-2012, 09:12 AM
What would be the best thing to do next.
1. Coolent filter
2. EGR delete or EGR/elbow
3. Oil Bypass filter
I have a H&S Minn Max and the DPF/CAT are deleted
Thanks for the help
Old 10-16-2012, 09:24 AM
2 then 1 then 3 is my vote.
Sent from a phone smarter than me.
Old 10-16-2012, 10:03 AM
Don't forget an air dog or another form of filtration for your fuel. Just my 2 cents. And maybe even a crank case vent due to how cheap and easy it is...
Sent from my iPhone using AG Free
Old 10-16-2012, 10:12 AM
Do #1 and 2 at the same time since you'll loose coolant during the egr delete. Otherwise if time is an issue then I would do the coolant filter first because it doesn't take very long. I am not sure how many people are actually using a bypass filter setup. There are probably a few other things you could do before the bypass filter anyways like the air dog or something like that which was already mentioned. Also the cold side pipe would be a good one to do as well when you do the egr delete.
Old 10-16-2012, 10:33 AM
I would vote egr delete with elbow first, then coolant filter. I dont think a bypass is really necessary if you change your oil on time. Thats my opinion anyway.
