Deltas in a 6.4l??? - Ford Powerstroke Diesel Forum
Old 10-10-2012, 07:42 PM
Deltas in a 6.4l???
Is this something as bad a the 6.0 was I noticed a very very big difference in my ECT and my EOT. I know in the 6.0 10deg difference was a sign if a bad oil cooler is this the same on the 6.4?
Sent from my iPhone using AG Free
Old 10-10-2012, 08:01 PM
I have read several posts where people say anything consistently over 15 and you should start preparing for an oil cooler replacement or at least a cooling system flush to try break open the clog.
Old 10-10-2012, 08:26 PM
Yup anything over 15 you most likely got trouble. I usually see 4 degrees on the highway
Old 10-10-2012, 08:37 PM
I'm about 4-6 average unloaded. 4-8 towing.
Old 10-11-2012, 01:04 AM
Ok so test it the same as with the 6.0 the. 60-65 mph and then monitor the temps?
Old 10-11-2012, 03:33 AM
I think you are supposed to test on flat ground at like 2200 rpms.
Old 10-11-2012, 06:20 AM
These are about what my delta's are also. Yes i believe the test is flat ground at 65 mph once the truck is up to operating temperature.
Old 10-11-2012, 06:34 AM
Ok I'll have to check it out my truck don't warm up on my way to work its too short of a trip and I saw 180 ECT and 80 EOT
