4" Diamond Eye Turbo Back DPF delete exhaust with muffler, want it to be quieter
Just had a 4" Diamond Eye Turbo Back DPF delete exhaust with muffler installed, would like it to be quieter. Still to loud with the muffler, any ideas on what I can do to quiet it down? I like the turbo whistle but would like it to sound like stock. I've heard of adding another muffler. Please help, thanks!
Put the cats back on it
I want to leave the cat out.
Why doyou not like how loud it is?
Yeah don't like how loud it is.
Dang man. You'd die in a 6.0L. My straight pipe 6.4L is hardy audible in the cab. But I plan on eventually muffling it.
I would check to make sure you installed the muffler the correct direction. Most modern bolt on kits have two different ways to install the muffler, one is louder and one is quieter. Other than thatc you have two options: throw on another free flowing 4" muffler, or add a 30" resonator from FTE. The resonator will probably get rid of the hair dryer noise, and allow the turbo to still sing a little bit. A second muffler would probably get it back to stock sound level, but just sound a little better. |
I have the Aero turbin muffler and it softens up the sound nicely.
Go back to stock if you want a stock sound. It's an aftermarket exhaust. No one buys an exhaust to sound like the stock exhaust, that would just be a waste of money.
Sounds like the OP jumped on the tune bandwagon without doing any homework... Sorry. |
you can tune a truck without making noise. sounds like you're the one on the bandwagon ![]() to the OP: get you a 51" Donaldson PN M090544 you can get it here: RYDER FLEET You can also incorporate a 4" glasspack up towards the front of the truck. That will eat up some turbo noise and further reduce resonance something like: THIS HTH |
for stock sound levels and better flow, a DPF/Cat delete on a stock exhaust would have been the best choice.
