Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
Old 10-14-2007, 10:08 PM
Rider25 Rider25 is offline
Best intake???
So i found this guy that is going to sell me a k&n intake pretty cheap? is it any good or should i get a different better brand cause i can get this one brand new but used not from a shop for 140. My truck is stock but im putting a 4 inch turbo back mbrp exhaust on it and later on a chip probably a sct. My truck is a 2003 f250 6.0 diesel crew srw. I ultimately want to maximize fuel economy and just make it run the best possible and always get more power from it. So please let me know. I appreciate all the help1
Old 10-14-2007, 10:14 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
actually -- save your $$$ and buy something else for the truck... your intake is good for a lot of HP.
if you just have to change it -- get a proguard 7 filter for the OEM intake. Also, do the Zoodad
The 6.0 intake is one of the better intakes out there and it comes on your truck stock!
Old 10-14-2007, 10:16 PM
hey thanks alot man, but shouldnt i get a different filter or something? i mean i have heard the same thing about the intake but i do want to increase power, so your saying its not worth 130, cause he agreed to that.
Old 10-14-2007, 10:17 PM
Tournaments Won: 1
I'd probably just change the filter and forget the K&N intake
Will save you $$$, you'll get better flow and better filtration. Then get to spend some of that saved cash on something else
Old 10-14-2007, 10:20 PM
sorry sorry! overlooked your post haha so ill get the progaurd 7 filter, anywhere you reccomend i can get this? and then what is the zoodad?
And also what did you think of your mbrp exhaust?
Old 10-14-2007, 10:22 PM
Tournaments Won: 1
hehehe, no problem --
I'd say call Pat or Larry at Discount Power Parts I think it is (DPP) or Raul at Stealth Automotive -- I'm sure either one of them will hook you up.... heck, you could even call Gus at Farm Boy's Diesel
and here is the Zoodad ... zoodad mod
and I love my exhaust! I put it in myself with a little cutting (comes long enough for a Crew Cab Long bed) and it sounds great and looks good! Notice a little more tone at highway speeds, but very quiet otherwise, unless you are standing beside the truck when its revved up
Old 10-14-2007, 10:23 PM
forddieseltweek forddieseltweek is offline
No linky?
Here is the link to aFe.... They are based in Cali
advanced Flow engineering (aFe) Air Filters & Intake Systems
Old 10-14-2007, 10:25 PM
Tournaments Won: 1
I had to open another window to go get the linky
hehehe, just got to it before I could edit
Old 10-14-2007, 10:32 PM
Alright thats good news about the zoo dad, looks great, i will get that done! now i see that you have an afe intake, why didnt you reccomend that one?
Old 10-14-2007, 10:49 PM
Tournaments Won: 1
Because I have a 7.3 -- its intake design is different and VERY restrictive and was helped by a new intake -- heck, I only got a used Stage 1 (couldn't afford the Stage 2) and could tell a difference!
but on the 6.0, you're intake is designed to be almost as efficiant as it can be from the factory (until you get up in the 500 ish HP range, then it just won't flow enough air I'd suspect) -- so basically you can make it better by adding a better flowing filter -- but then I would just leave it like it is
