H&S Blackmaxx tuner
installed tuner on a 2010 f350 powerstroke with manual tranny.love it except the fact can not get cruise control to work.tried the run in 4th gear and it actually worked but dry shifted into o/d like they said but it would not work in o/d.could use any advice anybody might have.thanks
I know everytime I update my mini max the cruise doesnt work. I have to turn the truck off then back on and it works like a champ. However, I have an auto trans and do not know if that makes any difference.
I really want a supercab dually with the manual trans. I bet it pulls like a beast tuned! |
yes, it makes a difference. this is a known issue with the h&s on manual trans trucks
it does pull like a beast,but i have had tuner on since truck was six months old
so i take it there is no known fix for problem |
Mine does work dry shifting. The other way mine works is if you push in the clutch from 3rd, put the shifter in neutral, let out of the clutch, and then slip it into OD.
contact H&S their customer support is fantastic
H&S is aware of the issue and is working on it, but their "shop" 6.4 is an auto, so they need a manual truck to do testing on
