Cost for install of EGR delete - Ford Powerstroke Diesel Forum
Old 07-25-2012, 06:17 AM
What should it cost to do a EGR delete with elbow, new cold side pipe and new boots. I have the parts and I'm not sure if I have the time or patience to try it.
I was quoted $1200 from Maryland Perf. Diesel and they said they would pull the cab (not crazy about that idea). I thought it was more like a 3 to 4 hour job with a pro and no need to raise cab?
Thanks
Old 07-25-2012, 08:09 AM
Send a message via Yahoo to upd103 Send a message via Skype™ to upd103
I paid $1850 for MinMaxx, EGR Block, DPF delete pipe, and installation for everything.
Then again, I'm in Texas.
Not sure if that helps, but my cab stayed on the truck during the process.
Old 07-25-2012, 09:00 AM
you can see the parts prices online. if you order outta state theres no tax. a shop will charge you tax and possibly a markup as well which is perfectly normal. the cab off thing might be a miscommunication.
egr delete kits with elbow range from 250+.
cac pipes are 200+.
boots? depends on which one or set.
i was quoted 350 for labor for the egr delete locally before i did it myself.
with those numbers you can see where you should be. good luck.
Old 07-25-2012, 10:07 AM
You dont need to pull the cab for that. We would charge 5 hours labor.
Old 07-25-2012, 10:14 AM
This sounds about right. I've done everything on my truck myself of course cab on. Everything is straight forward especially with the tutorials on here. Any reason you don't want to do the installs urself?
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 07-25-2012, 10:23 AM
EGR delete took me 8 hrs in my driveway. But I was all by my lonesome too... However all the DPF delete, EGR delete, intake, exhaust, tuner, downpipe, etc is pretty easy to do and I've done all the work on my truck myself. So I would encourage you to just think about using your own 2 hands to save a ton o cash...
Sent from a phone smarter than me.
