tuning problem?
Saturday I set my truck back to stock. I wanted to retrieve my stock file off the Livewire and save it to my computer. I did that and updated the SCT program and everything went fine. Went down to my truck, hooked up the battery charger and went to load up the xtreme mild file. Everything went fine,took the Livewire off and I kept the charger going for another half hour. An hour later the charger was still going for some reason so I shut it off unplugged it and had to get going. Tonight now, I went down to the truck, and it was dead. Lights were flickering and no crank. Got the battery booster out and started the truck.
Then, went for a ride and the truck was a complete smokey pig. Came home and loaded the street tune, no difference. Then, reloaded the stock file and still smoked like a pig and no power. Everything I try and nothing is doing the trick. Everything was fine when I parked the truck when I put it away Saturday morning. Did not hammer on it or anything different. I was previously running Xstreet with no problems. Now I am just frustrated with a truck that doesnt run right at all. Truck builds boost and power is just not there with a ton of smoke Anybody have any idea what the issue could be? I dont have any check engine lights just a couple codes. C1155 P2263 P1000 That is all I got. Ideas?? |
Truck was dead again this morning. Took battery cables off and charging batteries now.
Will the truck run that different if battery voltage is not right? Hoping that it is just the batteries? |
It sounds like it could be the batteries. From what i have read the truck can do all sorts of weird things if the batteries are bad.
Thank you. Left battery is shot. Right one tested good.
Yup new batteries should fix the problem bro
Anyone use Duracell automotive batteries?
Sent from my DROID2 GLOBAL using AutoGuide.Com Free App |
Batteries didnt help. Started and it was white smoking. Drives like a turd and misses. It might be turbo acuator but I dont know what is going on. It smoked white awhile then started to smoke black. It is like it is in limp mode, no power.
Do you still have the egr coolers? How is your coolant level?
What was weird is that it was smoking white almost then once I drove a little more it started to smoke black again and just kept on smoking black |
Do egr valves stick on 6.4s like 6.0s?
