installed a cold side cac pipe today
after the egr delete the intake elbow was not lining well with the factory pipe. the boot was a tad short on the verge of slipping. luckily the flo pro was delivered quickly and i was able to install it today.
![]() unbolted the top support. there are a couple spikes that hold it in place so you have to gently roll it up after everything is unbolted. looks like one side was broken off by a ford tech when my radiator was replaced. pulled out the stock pipe and installed the new one. placed the support back over the pipe and made marks to grind. after a few times going back and forth marking and grinding everthing fit perfect. as a matter of fact the pipe lined up well with the intake elbow and no longer does it need a longer boot. buttoned everything back up. sprayed the ends to check for leaks. the two plugs needed tightening and that was it. just need a test drive now. ![]() ![]() ![]() ![]() ![]() ![]()
Congrats man, looks great.
Whats the price on the flo pro pipe?
How was the install on the pipe? Can you install that without the EGR delete and intake elbow? I am waiting until I hit 125k miles before I do the EGR delete with Elbow. that is only 10k miles away I might just wait and do it all at the same time. Any noticable performance gains?
I didn't notice any performance gains. Sent from a phone smarter than me. |
Well my extended warranty I bought bumper to bumper runs out at 125k, my H&S turns OFF the EGR anyways, deleting it will just be peice of mind. So how was the install of the CAC pipe, egr delete plates and intake elbow?
i think a aftermarket cac pipe will fit the stock elbow. i thought i read it somewhere. i normally do one thing at a time and get a good baseline. so i started out upgrading to the 300hd tune and felt the urgency to do a coolant flush since theres so much crap in my cooling system so did the egr delete. after the delete the stock cac pipe was not fitting well so i put this one on. now im ready for the flush. so unfortunately each mod didnt get the attention i wanted to give it before doing more. anyways had turbo'ed motors in the past and noticed gains just by replacing kinked up pipes. this one is a no brainer. onto the coolant flush and then a downpipe. |
What did you have to grind? I still havent done the coolant filter, my degas bottle looks like brand new, never seen anything dirty in it.
