pyro on mini max only reading 92 - Ford Powerstroke Diesel Forum
Old 07-13-2012, 03:42 PM
Anybody else having this problem my pyro only reads 92 degrees all the time and was wondering if anyone else has had this problem and if so how to fix it. thanks
Old 07-13-2012, 08:52 PM
I have a similar problem, my readings never really go above 210. From what I have read and talking to H&S about this it appears my stock probe crapped out. This may not be the same problem, but people are probably going to ask what ver of mini maxx you are running as well as if you have checked your connections for the EGT probe, oh and you are selected to "factory probe" under user options.
Old 07-14-2012, 04:32 AM
what are you reading it off of? 92 seems like ambient temp. if truck still running then signal from probe is getting thru [to pcm]...or are you getting a wrench lite?
Old 07-16-2012, 01:49 PM
THat's funny I found this. My EGT's are reading 92 degrees also and not varying. I am going to call H&S.
Old 07-16-2012, 01:50 PM
It can't be the stock probe because the truck would throw a code.
Old 07-16-2012, 02:15 PM
I, 1, 2, 1/2, 6
hmmmmmm what'd h&s say
Old 07-16-2012, 02:32 PM
There is an option of pyro 1 & pyro 2 in the guage setup.
Old 07-16-2012, 06:21 PM
I called H&S and they said it could be the stock probe, the problem I have is not that it is reading 92 but it reads anywhere from 140 to 210. I did a little more investigation, and from what I can see, when the truck was stock it was not reading the right probe on my scanguage because i hooked the scangauge back up and got 1492 or some random number way up there when the truck was cooled down. I ordered a new one, its 40 bucks, if that doesn't fix it then i am out $40 and its back to the drawing board.
Old 07-17-2012, 09:37 AM
I made a similar post since I never saw this one, can't believe I missed it but yea I'm in the same boat
H&S Mini Maxx / Pyro reading
Old 07-17-2012, 02:14 PM
the rear sensors read 1492 w/ the H&S tuning on them... I think it's how they prevent regen?
