2008 Job1 - need clutch solenoid? - Ford Powerstroke Diesel Forum
Old 07-06-2012, 09:20 AM
From what I have been able to glean from the forums, it seems as if installing a direct clutch solenoid on a 2008 Job 1 (such as the GoGo) is a good preventative measure. Can anyone confirm or deny that statement? BTW - I am running H&S minimaxx on wild (when not towing), but I go easy on the skinny peddle.
Old 07-06-2012, 10:26 AM
do you ever have any issue with your tranny slamming into gear after coasting for a while?? i thought i had an issue with one or two of my selenoids when i was running the IPD Extreme street and Extreme Race tunes. after coasting for a few hundred yards and braking, i would get back on the pedal and the engine would rev then slam into gear. I've since switched to the KEM 345 and haven't had any issues with gear slamming..
Old 07-06-2012, 10:28 AM
I haven't noticed any rev-slam issues...just a hard clunk going into reverse when the truck is cold.
Old 07-06-2012, 10:49 AM
hmmm... i dont have that issue. if you are parked nose down on a hill when you're putting your truck into reverse without using the parking brake, you may hear that clunk.. i get that sometimes.
Old 07-09-2012, 06:44 AM
For me the gogo DD solenoid made a huge difference. I had a shift flare between 3 and 4 and it got rid of it completely.
Old 07-09-2012, 02:45 PM
Fixed the same issue on mine. Shifts tighter thru 3-4-O/D.
Old 07-10-2012, 09:25 AM
How are is the install? I couldn't find any instructions anywhere.
Old 07-10-2012, 09:34 AM
Its easy to install when you drop the pan for a tranny fluid change. All you do is take out the old solenoid and install the new one. Evil eye sent me a diagram of which solenoid it is. I will see if i can find it. If not Doug from gogo will know.
Old 08-05-2012, 03:34 AM
where is this solonoid obtained from
Old 08-07-2012, 10:59 AM
GoGo Diesel DirectSOL Modified Direct Clutch Solenoid Ford Powerstroke 6.0L / 6.4L
