How do I get my EGT to show up on a Spartan - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-04-2012, 07:18 PM Thread Starter
Boom's Avatar
I do not see the option to see my EGTs. Am I missing something?
2008 F350 Lariat Supercrew
Spartan-300, DPF delete, S&B intake, 2.5 leveling kit, CCV mod, LEDs everywhere
7xOEF 1xOIF Veteran
Boom is offline
post #2 of 8 Old 07-04-2012, 07:44 PM
08stroker250's Avatar
EGRTA - Exhaust Gas Recirculation Temp sensor A
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 8 Old 07-04-2012, 07:48 PM Thread Starter
Boom's Avatar
Ok what should a normal temp be? What is the highest that you should see. It is hot down here 115 on some days and I am running the 300 tune. Just want to make sure I am being safe. Thanks
7xOEF 1xOIF Veteran
Boom is offline
post #4 of 8 Old 07-04-2012, 07:48 PM Thread Starter
Boom's Avatar
Do I need any of the 4 sensors plugged in for this?
7xOEF 1xOIF Veteran
Boom is offline
post #5 of 8 Old 07-04-2012, 08:21 PM
I would set the high warning at 1400 and the high limit at 1600. You would have to be hard on the throttle to see either temp but those are good numbers to watch for if you are ever in it hard. You're going to see 500-1200 on a daily basis.
No. This is a pre-turbo sensor.
Jeff Dodd
post #6 of 8 Old 07-04-2012, 10:14 PM Thread Starter
Boom's Avatar
Ok just checked and I do not have EGRTA all I have is EGR error then Engine Coolant temp. So....what do I do?
7xOEF 1xOIF Veteran
Boom is offline
post #7 of 8 Old 07-05-2012, 05:21 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Are you looking in under Guages on your DashDAQ?? It's on every gauge style (you might just need to scroll thru some pages) and sometimes it looks like an analog gauge instead of just a digital number.
What gauge style are you using? If I was home I would change mine to the same and post a picture of where, but I'm sure someone else will be kind enough to do the same. If you haven't figured it out by Sunday night I'll post up a picture.
Sent from a phone smarter than me.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #8 of 8 Old 07-05-2012, 08:24 AM Thread Starter
Boom's Avatar
I got it. I just had to update it almost 23 times and it brought up a bunch more gauges. Thanks for the help.
7xOEF 1xOIF Veteran
Boom is offline
