H&S Mini Maxx - Ford Powerstroke Diesel Forum
Old 06-30-2012, 06:05 PM
bts bts is offline
H&S Mini Maxx
Hey guys, just bought the H&S Mini Maxx. Couple of questions?
First, how do you tell what tune you have loaded? Is the an info screen?
Second, does the hot damn tune come pre-packaged when you do the update from H&S website?
Third, how do you select and load tunes on the fly?
Thanks for the help.
I've got a 08 F250 with the 6.4
Old 06-30-2012, 07:55 PM
Congrats on the purchase. Stock the tuner comes with the mild set of tunes. Apparently with the new update h&s just recently posted about and came out with, which is. 36 I think, everything is on it so once you get the. 36 you have everything it sounds like (mild & hot damn & easy tunes and all transmission tunes). Then when you load you choose. With all versions of h&S's tunes you get 4 power levels. You only get one tranny tune though. You need to download those. You should find and read that post. I forgot what its called but its obvious. Just follow the directions and you will he fine
Sent from my LG-P509 using AutoGuide.Com Free App
Old 06-30-2012, 09:21 PM
From what I gathered when I loaded my tunes last night you don't get the hot dam tunes. When you have the tune loaded you will be able to adjust the tunes with the two large buttons on the right, and you will see the tune change on the screen.
Old 06-30-2012, 10:40 PM
If you update your tuner to the latest tune which is 6.4.37 you will have all three tunes easy, mild and hot damm. You choose which tune you want to run during the download process onto your vehicle. It also will give you the option of transmission tunes a little way into the download process.
Old 06-30-2012, 10:43 PM
Well I just updated my Blackmaxx to the latest (6.4.34) and I didn't see it, maby I'm just slow today. I'll have to check
Old 06-30-2012, 10:48 PM
Smile
It should have it loaded. I have a mini but I think they are the same except the update number might be different between the mini and black. When you download onto your truck it should ask which tune.
Old 07-01-2012, 07:51 AM
bts bts is offline
Thanks all
