H&S question, axle wrap?
I have a mini maxx and just finished my full exhaust install with down pipe and put the hd 300 on the truck. I went for a test drive with it on hot and i feel my bolt on tuned 6.0 had more tq out of the hole? it used to spin 35's like nothing my 6.4 is also on 35's but not even a chirp. I checked and it is on the hd300 is this just me? Am i getting bad axle wrap that's why it feels this way? Just lost thought there would be way more power, maybe i expected to much? Still love the truck either way and it smokes like crazy.
Also are fabtech traction bars good as i can get a pair at a good price?
You should have a ton of power. Are you sure the power level is hot? |
My tires have no chance on the HD300
it is on hot using the medium shifts and only seeing 33psi of boost is this correct? All the temps are in check in mashing it both stay at 190 the tranny was 160 i believe. Gonna do a tranny fluid swap tomorrow.
also running the stock intake could this be holding me back that much?
Depends too on what low boost fueling your on. My truck felt like a pig out of the hole on 5, runs the best on 3. been running the kem 210, it is my favorite.
You should be seeing more boost than that. Is your boost defuel set to low?
i reloaded the hd 300 today and set the low boost fueling to 2 didnt feel much different but saw 40-41 psi of boost this time. ordered intake and going to install it with an egr delete next weekend see if that helps any.
Is your filter minder coming on. My truck would suck the filter minder in with an S&B intake with the lid on.
