How many tunes come with spartan and H&S
Just trying to figure which tuner I want to go with. How many different tunes come with each of these two tuners? Can you tow with any of the tunes? I like the idea of shift on the fly, but if spartan comes with more tune options..... Can you use the tow/haul button with any of the tunes verses using a tow tune? Doesnt the spartan take a while changing tunes?
Also is one easier to install verses the other? And mounting, does one mount better than the other? I heard the spartan has better monitoring than the H&S.
I can only speak for H&S but the install is super easy and they come with 4 tunes out of the box. You can download many more including custom tranny tunes as well. Plus if they come out with new tunes, they are free to download. Give H&S a call and they can answer any question. Also check out ptp when you are ready to order.
Performance Truck Products - DPF Delete Kits & Diesel Performance Parts from MBRP, H&S, EDGE, Diamond Eye, Banks, BullyDog 2008 – 2010 6.4L Powerstroke - H&S Performance |
How many tunes can you store on the h&s at any given time, only 4? Can you tow with the higher HP tunes safely?
Easy with 4 shift on the fly settings Mild with 4 shift on the fly settings Hot damm 4 shift on the fly Easy tunes cycle the EGR 6 transmission tunes - 3 that lock the tc in 4th and 5th gear low med and high shift points & 3 that lock the tc only in 5th gear with low med and high shift points They don't have a specific tune for towing. |
Also they say not to use the tow haul in any setting other than the stock setting in any of the tunes easy mild or hot damm unless it is just being used for the purpose of slowing down coming down a hill or stuff like that
And you keep all 12 tunes on the hand held device or only 4 at a time? Sorry just trying to nail this down. I'm leaning towards the h&s right now
Quick question, so does that mean when i do the latest update on the h&s website i dont have to pick the hot damn tunes and the shift schedule i want? It automatically loads all of them and then i choose when im downloading it to the truck?
Quick answer, yes
