Head Studs question
Hey boys planning on getting head studs. Should I replace the headers while im adding head studs? I don't know much about the subjuct, just thought I would run it by my new best buds.
Headers?
You'll want to deck the heads and replace the head gaskets. |
Would you be referring to your exhaust manifolds?
Don't think so I plan on spartan or H&S tuning, turbo back exhaust straight pipe (Dpf delete), intake, EGR delete for now. Future- fuel system, differential lockers, and head studs. My question is while im getting head studs do I need to do anything to the headers?
Do some research before you start planning to do work to your truck. |
Thanks all in the process man. This is apart of my research, just impressed of the knowledge on here. I heard on the 6.0's the cab needs to be pulled to do a egr delete, is that true and is that the same case for the 6.4's. I know I can handle the tuner/turbo backed straight pipe but I think I will have the head studs done for me. I know a fella. Any suggestions?
Dont need to pull cab for egr delete. Head studs you dont have to but its the better option to pull cab.
