6.4 batmowheel with factory bolts?
I am considering putting both batmowheels in my 6.4. Do you all think that the factory headbolts could handle the extra PSI in boost created? Ive been reading many threads about 6.4 headbolts and i have seen both opinions stated, but most seem to say that the 6.4 headbolts are pretty good unless adding nitrous or something crazy like that.... Whats your opinion???
mine weren't, guess it's all luck
I think there is only one for the low pressure side.
theres two different ones, one for the "big turbo" and one for the "small turbo"
dang I wish there was when I had mine put in.
I am also wanting to put batmowheels in my turbos. I am hoping to do it this fall or next spring along with a ported intake manifold. I am still on stock headbolts.
me also. 2 batmowheels and ported intake and airdog.
IF it was ME and since i was all ready messing with the motor i would just go ahead and put APR head bolts on. You want have to switch gaskets so it will make it easier. Better to do it now with the gaskets good then wait tell you blow one and have to pull a head which would make it a WITCH
Pay now or pay later. You will eventually need studs running high horse power tunes. I would do studs if the cab is coming off.
I had only the Low Pressure Batmowheel and my factory studs chit the bed. I knew mine were going to go sooner or later, but I ran it hard for a while anyhow.
| Tags |
| 6.4, batmowheel, head bolts, head studs |
