Airdog II install ? the electric? - Ford Powerstroke Diesel Forum
Old 05-23-2012, 07:22 PM
Feedback Score: 10 reviews
hey guys ive got my my airdogII installed on the inside of the driverside rail , following instructions to a tee , but the instructions ,look like they mounted it on the outside of the rail even though it says inside , anyway only hold up is the wiring THE RELAY CONTROL LEAD , it says tap attached to the oe fuel pump , In the instructions it has a arrow pointing from the mini fuse tap to the oe pump ,airdogII.pdfdo i attach the mini fuse to the plug or do i actually splice a wire from there to the power wire of the oe pump? - thanks for any help
Old 05-24-2012, 06:51 AM
Just had mine installed on Monday. Here is my intrepretation of the instructions below, I believe you need to cut the fuse tap completely off and splice the wire into the fuel pump lead. I forget which wire to splice but search the forums and you'll find it.
Also, if you haven't done so already, write the serial number of the pump down now before you install. I forgot to do so and now I have to remove the unit from the bracket in order to get the serial number for the warranty.
6-2. Route the AirDog®II 'Relay activation lead', the Red (+) wire with the mini fuse tap
attached, to the OE fuel pump. Remove the mini fuse tap and splice the relay lead to the OE fuel pump lead.
Old 05-24-2012, 09:52 PM
dgibbs - thx for input , yes I talked to eric at PTP and the red wire with fuse was cut off and i spliced to power from the oe pump , went super easy after that !!just was un sure , And as for model # LOL i had it installed but was able to take a pic with my camera phone so all good !!!
Old 05-25-2012, 02:15 PM
No problem, glad I could be of help to you.
