CAI, help with smoke
Whats up everyone? Quick question. 2008 6.4 I have it deleted with H&S Minni but I do not have a cold air intake, just stock still. When I get a little aggressive with the skinny pedal like getting on the freeway or passing someone I get lots of smoke out the tailpipe. Will putting the CAI on help solve this problem? I'm thinking its just not getting enough air compared to more fuel with the tuner. I think its fun sometimes but I don't like being that guy rolling coal all the time, I just want to stay under the radar, if you know what I mean
Actually I guess it was when I was at a dead stop that I noticed an improvement but the throttle response didn't seem as good as when it was at 3
Yes an intake will help clear up some of the smoke. But depending on what tune you run, there will still be plenty of smoke when getting on the go go pedal.
If you keep the tuning the same then yes a cold air intake will lessen the smoke some. Or you can change your fuel settings or you could do both.
Thanks guys for the help. I'll be ordering an S&B, When you guys mention to turn the fuel settings down how exactly do you do that? I'm not very savvy with this tuner but I guess I could give H&S a call on Monday.
You have to go through the download tune process on the mini maxx again and it should ask you about LBF or low boost fueling 0 is the least smoke 5 will make the most.
Sounds easy enough. Thanks for your help
No problem
