performed CCV and now billowing white smoke - Ford Powerstroke Diesel Forum
Old 05-17-2012, 02:24 PM
performed CCV and now billowing white smoke on first drive through the exhaust? Any help appreciated
Old 05-17-2012, 04:06 PM
Make sure that hose is not obstructed. Check the flow at idle and if it isn't blowing hard the check for kinks or obstructions. Other than that, I have no idea.
Old 05-17-2012, 06:34 PM
Mine did that for about 2 days on a trip to Kentucky then it went away, i figured it was all the oil build up for running without the mod for 30,000 miles.
Old 05-17-2012, 06:38 PM
Are u sure it's coming out of the exhaust pipe? Or is it coming out of the vent tube? Mine smokes a good amount out of my vent tube once it gets up to temperature
Old 05-17-2012, 06:54 PM
Mine came out the exhaust pipe, think about it you run it for all them miles dumping oil back in the inter-cooler then stop,well some of will burn off with the condensation it created,i don't know i could be wrong but mine smoke for two days then stopped.I also put it back to stock for warranty work, then hooked all my stuff back up after i ran it stock for 2 weeks ,guess what it smoked for 2 days. White smoke that is
Old 05-18-2012, 03:12 AM
I did find a kink in the hose causing the issue, all seems to be good now, though it took 10 or so miles to clear up. Thanks for the help guys
Old 05-18-2012, 06:04 AM
That one inch hose can kink easily I check mine once a week but I'm paranoid.
Old 05-18-2012, 08:08 AM
i'm using 1" dishwasher hose.. it doesn't kink at all.. its really sturdy.
