Installed Spartan but... - Ford Powerstroke Diesel Forum
Old 04-29-2012, 09:53 AM
Installed Spartan and dpf delete. Went to the store and wont start. Have to load stock and the re load tune constantly. any help with this prob. Thanks
Sent from my DROIDX using AutoGuide.Com Free App
Old 04-29-2012, 04:04 PM
hmm sounds wierd, is the cable plugged in good on both sides? maybe go back through and load tunes over again
Old 04-30-2012, 11:10 AM
Sounds like something isn't hooked up properly. Call the office. 828-692-9967
Old 04-30-2012, 03:21 PM
Shouldn't be the cable you can run these without being plugged in.If its loose and not making a good connection that may cause a problem.
Old 04-30-2012, 04:38 PM
not sure how spartan connects to truck, but i had the exact problem with my h&s. the adapter to the obdII had wiggled loose. snugged it up, zip tied it, problem solved.
Old 04-30-2012, 05:57 PM
Thanks fellas, will be trying everything. If i dont get it right, i will give the office a ring. i really think its in the cable. might try replacing it if nothing else!
Old 04-30-2012, 06:05 PM
i guess i better change my boring stock sig to $hit eatin grin that a delete and spartan gave me
Old 04-30-2012, 06:09 PM
08MochaTanF350PSD
So you have resolved your issue? Was it indeed the cable?
You ain't "stock" anymore...change change change that sig!
Old 04-30-2012, 06:16 PM
well to be honest, it did it 3 or 4 times, telling me there was error, load stock tune. Once i did that, it would start, then i would throw the 275 tune on it and a day later i would go to start it,dead. i have it unplugged now, and so far so good. i havent had time to really go any further than this. u think it may be a cable? i am leaning that way for now.
Old 04-30-2012, 06:25 PM
08MochaTanF350PSD
Well, as a young IT guy way back in the dark ages, the 1st rule of troubleshooting issues was to check cables!!
So, it would be a good idea to verify your cable(s) are good! Outside of that, I'd call the Spartan folks and get the assistance needed to resolve the problem.
