batmowheels or the 71mm? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-27-2012, 11:44 AM Thread Starter
my 2008 has a spartan tuner 5" down pipe back exhaust, and an afe intake, I am thinking about either installing both the lp and hp batmowheel turbo wheels or the 71mm from elite. how much would this help my truck as far as performance wise, egt's and speed? i know it will clear up the smoke tremendously. Would i have to stud the truck to run the batmo's? i know i will have to with the 71, what other airflow upgrades should i install? I already have the down pipe, should i look into powerstroker67's dp, what about a cac pipe? newb question what is a cac pipe? intercooler? thanks for the help guys
levan4076 is offline
post #2 of 9 Old 04-28-2012, 02:25 PM
I would get the 71mm billet turbo from Elite and if anything add the batmowheel on the high pressure turbo. The 71 billet will give you a 150*-200* egt drop and adding the batmo to the hp turbo would only make that drop more. Power has been showin on the dyno with the 71 billet with a 50 hp gain over the stock turbo on a tuned truck with intake and exhaust.
Yes you will have to have studs to run both batmowheel in the stock turbos as you will be about 55 psi of boost with the big tunes.
08BIGRIG is offline
post #3 of 9 Old 04-28-2012, 04:44 PM
sanman28's Avatar
So.........if one were to do the 71mm atmosphere turbo upgrade, would it give you 300hp tune like power while your set at a 250hp tune setting. As an example.
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
post #4 of 9 Old 04-28-2012, 08:18 PM
More or less, but the higher your tune, the more you will see out of the turbo.
08BIGRIG is offline
post #5 of 9 Old 04-30-2012, 06:20 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I think i am going to run the batmowheel and a ported intake manifold.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 9 Old 04-30-2012, 07:21 AM
blackcloud2k's Avatar
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
I am still unsure what I am going to do. Been asking myself this same question.
2015 F350 Ruby Red Platinum, SRW CCLB, Color matched Ranchhands, rigids.
SOLD:
blackcloud2k is offline
post #7 of 9 Old 04-30-2012, 11:04 AM
08stroker250's Avatar
71mm without a doubt. Easily the best budget option out there. The power you get for the money makes it very worth it. Not to mention the potential power down the road.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #8 of 9 Old 04-30-2012, 03:46 PM
sanman28's Avatar
Yeah, but you gotta do head studs for the 71mm right?
FBHO
sanman28 is offline
post #9 of 9 Old 04-30-2012, 06:45 PM
You really need head studs with stock turbos and a big tune, so studs with any turbo upgrade would be ideal.
Jeff Dodd
