Cold air intake or no
Hi guys new to the forum (forums in general) so if this topic has already been covered I truly apologize. Just bought a 2010 F250 6.4, and I couldnt be happier. I was looking into cold air intakes and began to wonder if it was really worth it, there really arent many bends/curves in the factory box, and it doesnt seem like the cold air intakes out there are really grabbing at any colder air. Could I just buy an aftermarket filter and get comparable results as if I used a cold air intake?
From what I have read and seen the CAI really comes in handy when you tune and delete your truck.
It definitely wont hurt though. Sent from my Back Pocket |
An aftermarket filet is better than stock for sure if you just want to improve flow a little. If you plan on tuning and deleting the truck in the future (which I HIGHLY RECOMMEND) then I would just go ahead and buy a CAI. An aftermarket filter wont pull as much air as a cold air can, and If you try to run higher tunes then your gonna have trouble. Your truck will smoke like a freight train due to the fact that it cant pull enough air/breathe! Good luck. Try AFE or S&B, and check out Performance Truck Products - DPF Delete Kits & Diesel Performance Parts from MBRP, H&S, EDGE, Diamond Eye, Banks, BullyDog
No, you will not throw and codes or check engine lights at all with a CAI. They are also fine at the dealership for warranty work if you still are covered under factory warranty. A programmer and DPF delete are not typically excepted though..... Although it's still worth it in my book. Do yourself a favor and go check your oil. If your motor oil/dip stick smells like diesel fuel then that is proof enough that regens are killing the life span of your engine, and you should strongly consider deleting/tuning. If it doesn't smell bad yet, then just wait untill you have an excessive regeneration problem and you will see what I mean. Good luck and
I don't think there is much benefit to getting an after market CAI unless you are going to tune the truck. The factory one does a good job. However, as others have said, doing a dpf/cat delete will only do good things for the motor and then you should indeed get one.
Sent from my Autoguide iPad app |
Cool some great info here, right now Im looking into the H&S CAI, Ill let everyone know how it works out, I intend on programming/DPF delete, Im just taking some baby steps here, this is the first diesel Ive had where any of this was possible. Any help is greatly appreciated, thanks guys
I would strongly recomend doing the Cold Air Intake kit!! I would get a AFE Stage II as this is one of the best you can get for the 6.4 If I was going to get anyother setup, it would be a S&B intake, but I just think that the AFE is better. You will notice a BIG difference if you have your truck tuned and deleted with a cold air kit. Let me know if you need one as I know someone who has one.
