Mini Max, DPF/CAT Delete/ S&B Intake/CCV Mod/Coolant Filter
just got finished today...''Release The Krackin'' The Beast is ready for towing...
Nice! What did you do/use for the CCV mod? My coolant bypass filter is the on the way and I installed my AMSOIL oil bypass filter yesterday...did you consider doing one of those too?
YES, looking at Amsoil for next oil change. CCV Mod bought from Tractor Supply Company(on line), Hypro 1 inch Polypropylene Line Strainer with 50 mesh Stainless screen= $20.00. Then used 3/4 heater hose mounted it down on frame (clamped to frame mount) pass. side near coolant filter. Ran vent hose to rear of truck.
As long as someone doesn't tell you that your truck is on fire! On my 6.0 Excursion I vented to atmosphere (and never had a problem with droplets, just vapor) and I had a lady pull up to me at a stoplight and tell me my truck was smoking/on fire. I didn't have a lot of blow-by on that truck for starters, so she must have been pretty dang observant... The look of her face when I said, "it's OK ma'am, I know...it's a diesel" was priceless!
Ronin, If you dont mind me asking...How much was the amsoil set up? oil, filter and by pass filter?
I took it out for a test drive today....OMG...runs like a raped ape....cannot believe the power...and i was only on Mild...should get some real good fuel mileage on our trip cross country to North Carolina. Today, after lots of research, found the factory keyless entry code, and got that system working. |
Hope this helps, have a safe trip! |
ok, thank you, I have the Amsoil membership too. Will do it when we get back from our trip.
If you're not doing Blackstone oil analysis you might want to consider it. The Fumoto valve is pretty cheap and makes it real easy and it SHOULD help you feel better about dropping $500 on it!
Sent from my Galaxy Nexus using AutoGuide.Com Free App |
i was told that 3/4 inch heater hose was too small I used 1inch not sure if theres any truth in that but thought id throw it out there
