What is the procedure for setting a mini maxx to stock? - Ford Powerstroke Diesel Forum
Old 04-06-2012, 03:25 PM
Prior to going in for service? I know the dpf portion, just new to H&S....thanks
Old 04-06-2012, 04:03 PM
On the main menu select Install Download. You will get a message saying "The download is already installed" at that point you will be given the option to either "Return to Stock" or "Change Settings". Select return to stock and you will be flashed back to factory software. Just a warning, you will only be able to start the truck one time once returned to stock. After that you will need to plug DPF sensors back in, or install DPF removed tuning. Good luck!
Old 04-06-2012, 06:43 PM
Thank you!
