question about H&S trans tunes. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-01-2012, 11:41 PM Thread Starter
icecoastfreestyle's Avatar
I will be towing my 27ft enclosed car hauler with my 4 door jk jeep to Moab for EJS. Jeep weighs about 4500lbs plus gear and the trailer weighs in about 3k.. What trans tune is the best for towing? I will be going up through some mtn passes too.. I really dont care for the trans tune that came standard on my mini.. Thanks guys!
2008 f250 crew fx4- loaded up
Mods coming soon!
Came from the dark side(dmax) and am happy so far!
icecoastfreestyle is offline
post #2 of 13 Old 04-02-2012, 09:10 AM Thread Starter
Anyone?? I have heard the S2L is a good one. Insights on that??
Mods coming soon!
post #3 of 13 Old 04-02-2012, 01:21 PM
That is the trans tune I have been running. I like it because it locks up the TC in 4th gear and then shifts into 5th at 50 mph. I haven't towed with it yet so I don't know how well it will work for that situation or what effect tow/haul mode has on it either. The main reason I am using it is I think it is the best for fuel economy.
Hkyplr is offline
post #4 of 13 Old 04-02-2012, 06:49 PM
torqueshift's Avatar
Hkyplr....you should check ' show settings' on your tuner...only the Schedule 1 does the 4th gear TC Lockup.
Icecoastfreestyle....try the S2L..and do your trans re-learn.....as well as turning the truck on and off several times over the course of the day....the adaptive memory transmission gets better and better.
IMO....S2L works well for daily driving and hauling....for me.
2010 F-250 CC/LB H&S Mini Maxx (Mild tune on 'HOT'setting with S2M trans schedule 1/2qt over), S&B intake, CCV Mod, Flo-Pro exhaust DPF/CAT, Firestone air bags front&rear. EGR coming off sooooon..
2003 2500HD Dirtymax, Superchips OBD, AFE intake, Firestone Air bags rear, Western 8.6 plow, LED Light bar.
torqueshift is offline
post #5 of 13 Old 04-02-2012, 09:26 PM
You are right, I stand corrected.
I am running the S1L program, not the S2L.
Hkyplr is offline
post #6 of 13 Old 04-03-2012, 04:18 AM
sanman28's Avatar
I would try any of the second set of trans tunes......the first set all lock up the TQ in 4th and 5th. The second set only lock up in 5th. I run S2M for DD and towing. My TQ locks on the HYW at 50mph, and stays in 1-4 around town.
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
post #7 of 13 Old 06-11-2013, 06:38 PM
Did a search and found this thread.. So sorry to dig up and old one but rather than start a new one I found this one sort of answered my questions. I recently installed the Mini and DPF del kit. It's set on S1L trans tune and I did the relearn process as directed in the manual (in the performance tune). I guess the problem is I'm running my truck in the stock tune.. I'm not really interested in running hotter tunes, and I really don't like the way my trans is acting now.. So I guess the answer would be to change to the S2L trans tune and go through the relearn process again? What do you guys think???
lostbuckaroo7 is offline
post #8 of 13 Old 06-13-2013, 04:10 AM
superduty6.4's Avatar
How long have you have the tune loaded for? It will take a couple hundred miles to really smooth out. If you have had it loaded for awhile now and it still doesn't appeal to you then yes load up another tune and try it out. I used to do the re-learn but in the last few times I didn't and it really didn't seem to make a difference in the way the tranny learns so if you ask me the relearn isn't totally necessary. Just my opinion though.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #9 of 13 Old 06-13-2013, 08:17 AM
Thanks for the reply! I emailed H&S and this is the info they gave me (may be helpful for other folks that have the same questions):
"Thank you for the email. We would be happy to explain the differences. Based on what you have said, it sounds like you would be happier with the Schedule 2 Medium trans tune. For your convenience, the different options are explained below -
There are 2 shifting schedules that you will be able to choose from.
Shift Schedule 1 or "SS1" -
1st - 2nd - 3rd - 4th - 4th+TC Lock - 5th+TC Lock
Shift Schedule 2 or "SS2" -
1st - 2nd - 3rd - 4th - 5th+TC Lock
You will be able to choose a shift point - Low, Medium or High.
The shift points correspond to the throttle position, RPM and speed of the truck.
SHIFT SCHEDULE 1: For Shift Schedule 1 tunes, the LOW, MED, and HIGH modifiers will affect the 4th gear TC lock point, 5th gear shift point, and the 5th gear TC lock point.
- Low: as soon as the truck shifts into 4th gear the torque converter will lock up.
- Med: the truck will shift into 4th gear and accelerate to a med rpm speed and then torque converter will lock up.
- High: the torque converter will lock up in 4th gear, but you will get maximum speed and acceleration before it locks up.
We recommend doing the re-learn in the highest power level that you will realistically be running. If you will run it on Tow and never higher, Tow is fine. If you will never go above Stock, then Stock is fine."
post #10 of 13 Old 06-13-2013, 08:22 AM
Quoted: 48 Post(s)
S2 schedules will get the trans fluid really hot going over big mountain passes
drunk on diesel is offline
