Inter cooler intake pipe ???
Debating on different upper inter cooler pipes . Looking at the mbrp one or the one from elite diesel . Does anyone have any pictures of how much you have to notch your radiator bracket for the mbrp one ??
Anybody ,anybody .........
Debating between the mbrp intercooler pipe from Ptp which requires notching your radiator support , cost $169 Or Elite Diesels 6.4 Twin Tube Intercooler Pipe which doesn't require notching , cost $500 or No Limits both upper Intercooler pipes for $600 , not sure if it requires notching .. So if anyone has a intercooler pipe installed that had to notch there support ,please run out to you truck and snap a picture for me so I can see how bad I have to notch it so I can make a decision. I plan on ordering a egr delete kit to install sometime next week with a down pipe . Thanks |
I just put a MBRP pipe in and you do need to notch out quite a bit of material. I suggest taking out at least an inch of material to fit the pipe.
I suggest using a marker and marking the area that needs to ground out first before taking the radiator support apart. |
I have the mbrp intercooler pipe ,very little grinding needed ,i will get you pics tomorrow
