rear differential question - Ford Powerstroke Diesel Forum
Old 03-30-2012, 03:17 PM
hey guys i have a quick question to ask, just bought an 08 f250 psd and i'm trying to figure out whether or not it has a limited slip or just a one tire fire. did a burn out the other day and it only lit one tire up but when i launched it, it spun both tires. any help would be great!
it is two wheel drive also
Old 03-31-2012, 01:49 PM
sure it has a lim slip, the brakes prob held the left side tire till you launched
Old 04-01-2012, 06:56 PM
Ford axle codes I think you can find the axle code on the door tag as well, but I'm not sure if its the same code, but I would assume so. You may or may not have one, they weren't std. The LS in these truck are know for being worthless, Also remember its not a full locker so don't expect the it to act like one.
Old 04-02-2012, 10:05 AM
Fords limited slip sucks.....sometimes it works, sometimes it doesn't. Total joke. I have mine checked every time my truck goes in for service....I do it just to make sure there is documentation, so when it fails, Ford, can fix it.
Old 04-05-2012, 12:09 PM
gotcha okay i'll get the axle code and check it out, thanks for the help guys!
Old 04-05-2012, 12:13 PM
well according to the door code i have 4.10 ratio gears and its a non-limited slip. thanks again!
Old 04-06-2012, 04:41 AM
Question what is the dealer checking? is he actually pulling the cover and measureing the clutch discs? Or just checking that the fluid is correct?
Fords LS unit is a clutch type, they normally need to be replaced aroudn 25-30K miles. Beat on it and they need to be done sooner. They have used the same design since I can't remember when. It is not a lockup type, and depending on loading one wheel will slip while the other tries to get power.
Tru-trac is a better unit to upgrade to as it uses gears not clutches. The 450/550 D110 are Gear type LS units. I have 78K on my rig and the LS unit works just fine, but then again I do not drag race the machine just work it for what she is. Occasionally I can spin one wheel but the other will generally apply some power to the ground and get me moving.
