Exhaust Question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-29-2012, 04:19 PM Thread Starter
Exhaust Question
This is my 2008 F-250 with a dpf delete pipe and a MBRP 5 inch filter back from the delete pipe that I recently bought a couple months ago. All of these parts came on the truck like this. In this picture what is the part that is in front of the dpf delete? Is this the CAT? If so, would the truck run better with or without the CAT? Also in the second picture is the tail pipe. I just recently ordered a MBRP 5 to 6 inch tip because I like the looks of a 6 inch tip. Will the 6 inch tip stick out much? It is 12 inches long and I was wondering if I would have to cut the original 5 inch MBRP pipe back for it to fit with out sticking out a ton. Btw I am a newbie if you can't tell but I am very interested in learning more about the 6.4 Powerstrokes.
2008 Ford Powerstroke 6.4
2.5 Inch Leveling Kit
20 Inch Rockstar XD Series
33.5 Pro Comp Xtreme AT
Edge CTS Race Evolution
5 Inch MBRP DPF Delete Exhaust
Powerstroke6.4 is offline
post #2 of 8 Old 03-30-2012, 05:47 AM
smotrs's Avatar
Yes, that's the DOC or CAT as it's more commonly referred to. The truck may run just a little better, but you most likely wouldn't notice it. The truck would also be allot noisier and you would have more of the hairdryer/jet/torch/barrel-of-rocks sound with the CAT removed. Do some searches for hairdryer or jet engine sound to see what I'm referring too.
Welcome to the ORG.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT's
Avic-Z2 Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, Six-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares
Ravelco Anti Theft Device
Originally Posted by Rick Santorum
We went into a recession in 2008 because of gasoline prices.
smotrs is offline
post #3 of 8 Old 03-30-2012, 08:49 AM Thread Starter
OK thanks a lot. That helps to know. I will probably be removing it then. What about the tip? Will I have to cut it back so it doesn't stick out much?
post #4 of 8 Old 03-30-2012, 12:51 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
either cut it back or have it sticking out inside the tip hahaha. but yes, the pic is small but what it looks like is you have a 5" mbrp dpf back exhaust with no tip. what you want to do is get your new tip, slide it on the exhaust an dget it about where ya want it, mark it and cut about 2-3 inches towards the end of the pipe from where you marked it so that when u clamp it down it has pipe to clamp onto unless you bough a weld on tip.
like he said above that is the cat and you have just a dpf delete pipe, best thing to do is just to buy a dpf/doc delete pipe and bolt it up to get rid of the cat. these trucks arent very loud straight pipe. the hair dryer sound is the wooshing of the air from the turbos, it doesnt really have a whistle is just sounds like a bunch of air is coming through the exhaust. But if you dont mind a little turbo sound, then delete the cat. the cat prolly cuts down on the smoke a little and the exhaust wont smell as potent with it on there.
Hope ya like your new truck
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 8 Old 03-30-2012, 04:10 PM Thread Starter
Thanks so much guys. This helps a lot! When I get my tip I will probably cut some of the 5 inch MBRP so it doesn't stick out much. Could I cut the exhaust back with a regular hack saw? Or would you recommend cutting it with a different tool?
post #6 of 8 Old 03-31-2012, 01:47 PM
new2diesel59's Avatar
use a sawzall or a metal cutoff wheel for a 4 inch grinder, hack saw might take a minute, lol
2008 F250 sd ps cc sb
stock for now, in need of mpg!!
new2diesel59 is offline
post #7 of 8 Old 03-31-2012, 07:25 PM
travisH3's Avatar
Quoted: 2 Post(s)
I used sawzall with a fine tooth blade and it slices right through it.
T-rav
2010 F350 6.4-
travisH3 is offline
post #8 of 8 Old 04-03-2012, 04:25 PM
atwoojr's Avatar
I was putting on my 4" downpipe back exhaust and had to make a couple cuts so it would fit my short bed truck. I originally thought I would just hack saw it, got 4 strokes into it and said F that. I pulled out the jig saw and put in a metal blade. It cut through the pipe like a hot knife through butter. Just another option for you....Wish I had a sawzall for stuff like this.
*2009 F-250 CCSB Fx4 *Ranch Hand Front and Rear Replacement *Blue LED's shining on front and back floorboards
*Zebco 33 Mod
*H&S Black Maxx *Diamond Eye 4" *aFe and custom airbox *Color matched side vents *Home-made Coolant Filter *Fumoto oil valve
atwoojr is offline
