Anti Wrap/ Ladder bars - Ford Powerstroke Diesel Forum
Old 03-20-2012, 10:53 AM
I have been researching ladder bars for a weeks or so and I think I am going to do something like this:
Anti wrap bar
I haven't seen anything like this on this website and I want to get some opinions on it. I questioned the wisdom of using a shackle at the forward end of the bars because it seemed counter-intuitive, but after some more reading, it makes sense. I am a good welder so the fabrication seems pretty straight forward.
Let me know what you guys think
Old 03-20-2012, 04:53 PM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
That is a pretty good idea. Looks like it should work.
Old 03-20-2012, 06:44 PM
There's a lot more/better ideas that you can find @ pirate4x4.com. That setup is from a jeep I believe and don't think those heim joints would last very long on our trucks.
Old 03-20-2012, 07:09 PM
I'm leaning toward a johnny joint in the front on a shackle and bushings in the rear. I think I may try to emulate the PMF bars.
Does anybody know the geometry involved? It seems simple, but I usually mess things up when it seems simple.
Old 03-20-2012, 07:24 PM
Using three point hitch top link ends will be more than strong enough. I say this b/c of the abuse they go through behind the tractor. I have put many of hrs on the same old top link. Something like the PMF mount on the axle and a solid mount on the frame like a spring hanger should be good. Won't have much flex for offroading, but I assume the truck will see mainly on road. Just cut off the ends and threads in the tube, weld in a longer piece of pipe/tubing and you should be good in terms of the bar, but mounts will be the tricky part.
Old 03-20-2012, 10:17 PM
I'm dizzy after reading this thread: Traction Bars: A closer look - PowerStrokeNation : Ford Powerstroke Diesel Forum
I got some good info from it. I am definitely going with a three point design like the PMFs. I will have a bushing mounted above and below the rear axle and a johnny joint mounted to a shackle up front. I think I will mount the forward end on the frame right about where the bed and cab meet, maybe a few inches forward of that.
