traction bars - Ford Powerstroke Diesel Forum
Old 03-17-2012, 03:29 PM
traction bars
will traction bars work if you have Firestone air bags and a Hellwig rear sway bars?
Old 03-17-2012, 08:16 PM
Yes they will, I have both airbags and a BIG WIG Hellwig sway bar with my bars, I'm going to change out my bars for PMF here real soon.
Old 03-17-2012, 11:13 PM
Are you just getting PMF's bars with a 3-4" block? I believe that the stock block in the F350 is 4" although I haven't measured to confirm it. Wouldn't mind getting a 3" block with the tracbars since I run 30 PSI when empty but am slightly higher in the rear because of my airbags. Guess I'll just wait and see what your setup looks like.
Old 03-18-2012, 05:22 AM
The DRW F-350 block is two inches (measured yesterday for the same reason, wanting to get PMF traction bars).
Old 03-18-2012, 08:28 AM
The blocks will vary on what packages you have on the truck i.e.. (Camper/trailer pkg) I have both and my blocks are 3.75", I will keep the same blocks as I installed ICON 2.5 coils and and when I order the track bars Trevor said stay with same size blocks and truck will ride level, I only keep 10 psi in my bags when unloaded, which Firestone recommends you keep a minimum of 10 psi when not loaded.
