Up Pipes - Ford Powerstroke Diesel Forum
Old 03-12-2012, 07:03 PM
Up Pipes
I have a failing head gasket so the cab is coming off. I know some people have had up pipe failures and others don't (I haven't to date but I didn't have a head gasket problem until a week ago), but I really don't want to have to pull the cab again so I am thinking of upgrading the up pipes and manifolds while the cab is off. If anyone has tried any of the aftermarket ones, I would love to hear what ya think of them.
Old 03-12-2012, 08:24 PM
6.0 manifolds and modified up-pipes. Done.
Old 03-13-2012, 02:05 AM
Do you recommend any specific brand on the up pipes?
Old 03-13-2012, 05:55 AM
What about steed speed manifolds and custom up pipes? I think thats what Erik from PTP is running.
Old 03-13-2012, 06:30 AM
Check out Rudy's site or give them a call.
They would be great on a truck with big turbos and big fuel, but they are overkill on a basically stock truck.
Old 03-13-2012, 06:31 AM
Oh ok. That makes sense. If i ever have to i will just go with 6.0 manifolds and up pipes. I dont have plans for crazy power. Just reliability.
Old 03-13-2012, 06:34 AM
Yeah. $1,000 just for manifolds is steep when you only make 550-600 at the most. Those manifolds require custom up-pipes as well. Not a cheap option by any means.
Old 03-13-2012, 06:22 PM
Those things are tough as h#ll. When I saw the price on them before, I thought was with the up pipes (seemed to good to be true).
I am hoping to come across someone who has actually one or two of them to see what they perform like. I assume more flow would mean lower EGTs when towing, but I am not sure if the back pressure PSI was lower due to larger pipes if that would actually slow the spool up if you are stock on fuel side of the equation. Anyone know?
Old 03-13-2012, 07:52 PM
Here ya go: 6.4 MANIFOLDS **NEW NUMBERS** - PowerStrokeArmy
Good read, lots of info, and what I would call a questionable representation of data. Not to mention, the maker of the product himself seems to not handle himself well in public.
Old 03-13-2012, 08:21 PM
Thanks for the input!!!!
Tags
exhaust manifolds, up pipes
