Which tune and trans setting h&s - Ford Powerstroke Diesel Forum
Old 03-11-2012, 07:02 AM
Guys
Just setting up a truck for a friend 09 Harley 350 6" lift with 38's, I'm putting a mini max in it and I don't have any experience with them I run spartan in my cabelas He uses the truck for towing mostly 30' sled trailer loaded up probably 7000#'s. to the mountains almost every weekend. What should it set it at for tune and trans. And should he still use tow haul? I would think he should
Also the mini max will adjust for tire size right?
Thanks
Matt
Old 03-11-2012, 02:28 PM
Originally Posted by Oilboy View Post
Guys
Thanks
Matt
The good thing about H&S is the ability to shift on the fly with the levels of the tune. Ive seen on here that guys tow in mild and no power with out issues, Id say anything higher and you will just need to be careful and watch the gauges. As far as the trans tune goes, I really dont know, I am using the S2M because I saw on here it was a good middle of the road tune....From what I have seen on here, Yes he should still use the Tow haul while using the H&S. You will also find out when doing the initial download of the tune, it will ask a series of questions, one of those being "Adjust tire size". Click yes and then make the change to the 38's hes running. If anyone reads this that objects with what I have said, please feel free to correct me. I am just going by what I have learned from this site.
