Diamond Eye Downpipe-Back Installation - Ford Powerstroke Diesel Forum
post #1 of 41 Old 03-10-2012, 09:08 PM Thread Starter
Quoted: 45 Post(s)
I'm looking over the instructions ( Installation Instructions K4357A 2008-2010 Ford 6.4L F250/F350 4" Downpipe Back Race Application ) prior to installing the exhaust at some point and I had a couple of questions:
1. Has anyone had success at removing the stock exhaust without cutting or lifting the rear in Removal Step 4?
2. Did anyone have to cut the intermediate pipe in Installation Step 5?
3. In Installation Step 6, is the weld-on hanger already present or does it have to be added?
Thanks for the info, and any other tips are always appreciated!
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #2 of 41 Old 03-10-2012, 09:26 PM
atwoojr's Avatar
Ha, I installed this exact same exhaust yesterday. It was a little tougher than I thought it would be, but wasnt too bad. So to answer your questions...
1) I didnt cut a single bit of my stock exhaust. I unbolted every bit of it to remove it. I did have to remove the lower shock bolt and push the shock up as well as jack the truck up by the drop hitch. I had to remove that last section going forward, it would not come out the back side.....
2) I had to cut the second and third pipe. I ended up knocking off like five inches on the second pipe and like 2 or so inches on the third section. Everything ended up fitting pretty good....Lets just say I was pleased with my work and it looked good.
3) In the picture on top of the install manual, it shows each section and the hangers. This is exactly how it was shipped to me, my parts looked no different than the manual. And all sections fit into the factory hangers.
When removing the stock exhaust, I found it easier to unbolt all the hangers from the frame and then pull the rubbers off on the ground. I used a large pair of channel locks and opened them up all the way to press the rubbers off. I asked my wife what she thought of the exhaust install I did, her answer "Looks like you did a good job except for leaving all the stickers on the pipe" always a critic. I got that big grin everyone talks about when I fired her up for the first time.....
*2009 F-250 CCSB Fx4 *Ranch Hand Front and Rear Replacement *Blue LED's shining on front and back floorboards
*Zebco 33 Mod
*H&S Black Maxx *Diamond Eye 4" *aFe and custom airbox *Color matched side vents *Home-made Coolant Filter *Fumoto oil valve
atwoojr is offline
post #3 of 41 Old 03-10-2012, 09:34 PM Thread Starter
Quoted: 45 Post(s)
Wow, thanks for the quick and detailed reply! What did you use to cut the pipe(s) and I assume you cut both pipes because you needed the 7 inches? [Insert crude joke here]
Thanks again!
post #4 of 41 Old 03-10-2012, 09:41 PM
atwoojr's Avatar
Thanks again!
HAHAH My wife always told me it is never about the size.....But anyways back to business, I marked the pipe with a sharpie under the truck. I then pulled the pipe out and drilled a pilot hole, then went to town with a jig saw and metal blade. It sliced through that pipe like butter, I would say both pipes were marked and cut in 10 minutes, what took so long was climbing under the truck and climbing out 4 different times. I am not sure if only one pipe needed to be cut rather than two, but I had to cut the second pipe because the third did line up at the hangers. All I know is it fits and looks like it came from the factory with this exhaust. A very good investment, in my opinion.
*Zebco 33 Mod
atwoojr is offline
post #5 of 41 Old 03-10-2012, 09:47 PM Thread Starter
Quoted: 45 Post(s)
Sweet. I went with the stainless so maybe it will be a little tougher to cut but I'll find out eventually. My Mini Maxx will be here Monday but the exhaust had to come from Diamond Eye so it will take a bit longer. Thanks for the answers... again!
post #6 of 41 Old 03-10-2012, 10:01 PM
atwoojr's Avatar
No problem at all....I am just trying to make others lives easier by providing the easiest ways I did stuff, and the different things I may have done that didnt quite work out....On the down pipe connection, others may chime in but I removed the backside bolt using a 3/8" ratchet with a 3/8" to 1/2" connector then a 4" extender and then the 13mm(I think) deep wall socket.... You will soon find out about all this when doing the removal/install process....
*Zebco 33 Mod
atwoojr is offline
post #7 of 41 Old 03-11-2012, 03:31 AM Thread Starter
Quoted: 45 Post(s)
And this I have no doubt...!
post #8 of 41 Old 03-11-2012, 02:45 PM
atwoojr's Avatar
Howd the install go? Here is a picture from the back looking forward of the exhaust....
*Zebco 33 Mod
atwoojr is offline
post #9 of 41 Old 03-11-2012, 04:00 PM Thread Starter
Quoted: 45 Post(s)
I don't have the exhaust yet... Just ordered from PTP on Thursday and the exhaust had to be shipped from Diamond Eye... The tuner and stuff should be here tomorrow.
post #10 of 41 Old 03-11-2012, 04:09 PM
atwoojr's Avatar
My bad on thinking you were doing it today....So when doing the removal of the stock pipe at the downpipe, you will need the extension and and ratchet and slip inside the frame to get the backside bolt.
When reinstalling though, to bolt everything back up, use the ratchet on the nut side with like a 7" extension so the ratchet fits between the tranny cross member and skid plate. I was able to slip an open end wrench up on the bolt head side to keep from spinning when tightening down the nut.
O and by the way, I was way off with the amount of pipe I cut off. The second section pipe got 13 inches cut off and the third section got 4 inches cut off. Maybe it was vice versa but those are the measurements that were cut off.
*Zebco 33 Mod
atwoojr is offline
