top gun customz traction bars - Ford Powerstroke Diesel Forum
Old 03-09-2012, 06:53 PM
Feedback Score: 10 reviews
Hey , guys got these traction bars awhile ago and have had a string of good weather and some time so i installed finally , Didnt go with Pmf's Traction block because i was un sure on my lift heights ,These gave me an options and do the trick Top quality , sorry for big pics !! Yes the brackets need moved down i will edit pics once i adjust everything , okay heres how they are suppose to be mounted !!!
Last edited by diesel23; 03-11-2012 at 05:31 AM. Reason: the bracket was installed wrong this is correct
Old 03-09-2012, 07:01 PM
Those are....different looking. Glad they are working out for you!
Old 03-09-2012, 08:29 PM
Feedback Score: 7 reviews
What prevents the axle from not wrapping still. It looks like the axle could still twist with out having a top and bottom points preventing wrap. I don't know, I'm just asking questions because I'm in the market and I want something that works and not cost and arm and a leg for a work truck lol
Old 03-10-2012, 12:01 AM
The mount on the axle is suppose to be facing downwards. So that the axle wont wrap. But I am guessing your having ground clearance issues. If that is the problem, mount it on the top. Leaving it where it is, won't do much because the kit is bolted on and the axle will still pivot. I welded mine on but I have a 5.5" rear lift in the rear to mount on top of axle.
Old 03-10-2012, 06:28 AM
Anyone have more info on these. I'm thinking about giving them a try
Old 03-10-2012, 06:57 AM
what he said
Old 03-10-2012, 07:06 AM
I just emailed them to get info. They don't show them on their site. I will post up what info I find, they are open till 3 today so hopefully they get back to me. I thought they were a site vendor?
Old 03-10-2012, 07:08 AM
I'm trying to verify with jody from top gun customs now on if I installed correctly, I will know shortly, they definitely helped the axle from moving and improved my shifting at WOT!!! Very well made and super heavy duty
Old 03-10-2012, 07:17 AM
TravisH3, give them a call you'll have better luck, ask for Jody he's there till 2, he's the Guy to talk to there
Old 03-10-2012, 12:36 PM
They should have been mounted toward the bottom instead of the front. And that would also move the frame mounts back some. I mean they will probably help where they are, but just not as much like they are suppose to.
