EOT and ECT Temp Difference is Increasing - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-08-2012, 10:29 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
When I first got my Dashdaq/Spartan my temps were running ECT-200 and EOT-202ish. The difference has been building for some time now and now my temps are about 20-30 degrees different, with the Coolant temp being low and Oil temp being high. about 194 versus 215-220. What is causing this? I'm sure its "fine" but I want to fix it.
Sensor? Need a flush?
55K on truck, tuned for about 20K of that.
sjl2725 is offline
post #2 of 19 Old 03-08-2012, 10:45 AM
Clogged oil cooler?
2008 F250 CC/SB
cmalinowski is offline
post #3 of 19 Old 03-08-2012, 10:55 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
Well, that's what I was leaning toward, but wanted to throw it out there. So if its clogged, what's the best way to find out?
If clogged, can it be flushed out or do I need a new cooler? maybe blow it out with an air hose?
sjl2725 is offline
post #4 of 19 Old 03-08-2012, 12:34 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Monitoring your ECT vs EOT is the correct way to find out if its clogged. By the numbers you are seeing it is clogged. I would recommend a good flush and some cat elc. I would also recommend a coolant filter. That will help keep it from getting clogged in the future. I dont think flushing will unclog it but its worth a try. You could also back flush the oil cooler and see if that helps.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 19 Old 03-08-2012, 01:46 PM
kevinah's Avatar
Is it the difference in temps or the actual individual temps that is indicating the clog?
kevinah is offline
post #6 of 19 Old 03-08-2012, 02:07 PM
08stroker250's Avatar
There should never be that much difference in oil and coolant temps.
Oil cooler is probably the issue. It will more than likely need to be replaced, rather than just flushed.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #7 of 19 Old 03-08-2012, 02:13 PM
maddenjr's Avatar
Send a message via AIM to maddenjr
You are gonna need to replace the oil cooler
Spartan,Afe,Mbrp Delete with duals,Banks Intercooler,Custom CCV Mod,22.5 American Forces,Flo Pro egr delete,Lots of Strobes,Atomic Strobes,5%Tint and 20% Windshield Tint,B&W gooseneck,K3LA Train horns and some other goodies, Head studs and waste gate coming this spring
2001 F350 Flatbed/Car Hauler, Ext Cab,07 Front End w/Cowl Hood,SCT Tuned,MBRP Straight pipe
92 Mustang Lx Hatch X275 Drag Radial been low 7's
03 Cobra with a lil extra boost
maddenjr is offline
post #8 of 19 Old 03-09-2012, 02:41 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
Roughly, what does an oil cooler cost? Not installed.... Thinking I could do it myself.
sjl2725 is offline
post #9 of 19 Old 03-09-2012, 03:00 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
Uh yeah. Did a little more research... Not going to even try.
sjl2725 is offline
post #10 of 19 Old 03-09-2012, 04:02 AM
maddenjr's Avatar
... It sucks to do!
maddenjr is offline
