Puked! - Ford Powerstroke Diesel Forum
post #1 of 51 Old 03-07-2012, 11:41 AM Thread Starter
F35008's Avatar
Puked!
My truck pucked a little bit for the first time couple day's ago. It was the first time that I was running the truck on the 345 tune with egr off, I did a quick take off in 4 hi, not building boost, just floored it, and only up to the 5th gear, no lockup. I stop not to long after that and saw the smoke cumming out of the hood, it was from the degas bottle. Can it be my egr cooler that fail from the pressure or it can only be the heads?? Is there a way to check it?? And could it be an air pocket in the system? I got #2 injector changed couple day's ago, just wondering?
F-350 2008 SRW
5" from DP, 6" MBRP Tip, AFE cold air
H&S mini maxx on HD 300
20x10 XD Diesel chrome wheels
35x12.5x20 Mud Grapplers
Pro Comp traction bars
Built tranny with Precision Industries converter
My truck Burnout:
My Camaro Burnout:
F35008 is offline
post #2 of 51 Old 03-07-2012, 11:46 AM
Clayton1985's Avatar
Pressure test coolant system.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #3 of 51 Old 03-07-2012, 01:56 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
It is possible its the egr cooler but my guess would be head gaskets.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 51 Old 03-07-2012, 03:06 PM
DSTRBD's Avatar
So you still have your EGR coolers?
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #5 of 51 Old 03-07-2012, 03:22 PM
bentstroke_02's Avatar
the cap could be bad to if you havent updated it. Mine puked once but never again after the cap was replaced
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #6 of 51 Old 03-07-2012, 04:08 PM
NVHunter83's Avatar
Would a pressure test show a leaking head gasket?
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #7 of 51 Old 03-07-2012, 04:12 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 275 Post(s)
my vote is head gaskets
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #8 of 51 Old 03-07-2012, 04:55 PM
amb82's Avatar
Feedback Score: 3 reviews
Just an observation but I have been noticing lately that a few of the head gasket leak threads have been on the 345 tune. I too had a leak and had been running the 345 tune for about a month. I didnt have any puking but stubbled upon some signs of coolant in the turbo exhaust piping while installing some upgrades. Went with arp studs
2010 F-250 Cabelas Edition
Sct with Gearhead tunes, 4" afe dpf delete exhaust, leveled on 22's
amb82 is offline
post #9 of 51 Old 03-07-2012, 05:58 PM
08stroker250's Avatar
Sounds like head gaskets to me.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #10 of 51 Old 03-07-2012, 06:10 PM
might as well do head gasket, studs and push rods. Kinda sucks that ya have to dump that kinda money in it but at least it will be bullet proof
Jeremiah
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
