Mini Maxx with or without Pyrometer - Ford Powerstroke Diesel Forum
Old 03-06-2012, 05:27 AM
Getting ready to order the DPF/CAT delete from PTP but was wondering about the Pyrometer...Do i order the one with or without?
Old 03-06-2012, 06:07 AM
without, the 6.4 has a factory one.....this is one of the reasons setting your tuner up is easier on the 6.4.... on anything else you have to drill and tap a hole for the pyro in the manifold.. not so on the 6.4.... its pretty much plug and play after you pull off the garbage down below.. when ordering from PTP ,do the online chat and Nate will make sure that you are ordering all of the right components for your truck....
Old 03-06-2012, 06:25 AM
Thank you sir. Really tired of "Cleaning Exhaust Filter"
Old 03-06-2012, 02:46 PM
Let us know if we can help with anything.
Old 03-07-2012, 09:58 PM
getting ready to order mine too. What's this stuff down below?
Old 03-07-2012, 11:13 PM
He's referring to the DPF/DOC I believe.....
Old 03-08-2012, 05:57 AM
correct, the garbage would be your factory exhaust from tip to tail...
Old 03-08-2012, 08:46 AM
can we keep our factory exhaust minus DPF/doc? So factory muffler and tips? I want the stock look as far as the chrome tips go.
Old 03-08-2012, 09:27 AM
yes, you can also purchase a separate DPF and run in hollowed out... for a full visual factory look
Old 03-08-2012, 09:46 AM
I just want to keep the tips...this will keep me limited to a 4" delete pipe?
