Lighten the steering? - Ford Powerstroke Diesel Forum
Old 03-05-2012, 08:01 AM
Question Lighten the steering?
Is there any way to lighten the steering on my truck? as slow speeds its like driving a truck without power steering, (not exactly but you get the point). Whats with that? Do the 450/550 have a bigger pump or something? They have to turn the bigger tires so????? Anything? swap it out for a diffrent brand pump altogether? My fathers dodge 2500 runs taller wider tires and it turns much lighter....
Old 03-05-2012, 09:32 AM
thats weird.. mine is always easy to turn.. and i'm running 37x13.5's ... i dont have any problems turning while stopped although i try never to do it.. i dont want to blow a hose or burn up the steering pump.. i always make sure i'm at least moving, but i can turn my wheels from right lock to left lock with 2 fingers
Old 03-05-2012, 02:47 PM
Feedback Score: 8 reviews
You run 13.5" tires on a 8" rim?
Old 03-05-2012, 03:33 PM
All day everyday bud! Looks and rides great ... Air down the tire a tad... Keep them rotated every 10k They're wearing perfect ...
Old 03-05-2012, 05:43 PM
Send a message via AIM to maddenjr
My Excursion you couldnt turn at all at an idle but after i changed the pump it was perfect! My F450 with the 22.5's on it which are basically 37's turns like butter Maybe you have a weak pump
Old 03-05-2012, 10:36 PM
ive allready burned thru one steering pump and when replaced the problem went away but slowly came back after i got an alignment and rotated tires it went away.
Old 03-05-2012, 11:45 PM
I'm surprised that 08 body style is not turning easy. Everyone I drove turned like a Cadillac turn the wheel all the way wih one finger. I think you might have a weak pump too. My 04 isn't bad at all. But as do I always try to make sure I'm at least barely rolling or so before I start turning too. I don't want to blow a hose either. But when it is still I can turn with ease. But not as easy as the newer body style
