B&W HITCH WITH TUNE AND PIPES - Ford Powerstroke Diesel Forum
Old 02-20-2012, 01:36 PM
anyone with the goosenek hitch find a 4" or 5" pipe that fits over the rear axle without hanging low at the tail...i sure would like to know which brand.
Old 02-20-2012, 03:34 PM
Yep I know what you mean I hate how low the pipe hangs with the drop down bracket for the hitch. Like to know too.
Old 02-20-2012, 03:50 PM
I had the same issue, but I've also got a chop saw, sawzall and a welder. Now no more issue, tail pipe is back up in the factory location with the B&W hitch and supplemental air bags all there.
What I did was cut two inches out of each vertical section (as it goes up and over the rear end), then took one of those two inch sections of pipe that I cut out and added it into the top section (between the up and down sections). Worked like a charm.
Old 02-21-2012, 05:02 AM
My magnaflow 5" fits great with my b&w hitch. I will see if I can find some pics
Old 02-21-2012, 05:08 AM
pics would be great...thanks
Old 02-21-2012, 05:48 AM
Send a message via AIM to maddenjr
Im running MBRP duals with my B&W gooseneck and i have 6'' tips tucks real close to the body! No rubbing either and I load the hell out of my truck
Old 02-21-2012, 05:49 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
I have a B&W, 5" flo pro, and airbags and it all fits up under the truck with out the drop down. Things are close, but nothing rubs and rattles. Sorry this is the only picture I have. The tip sits about 3/4" below the pinch seam. Thats about as tight as I wanted it to the body. I have a buddy that has a 5" mbrp tail section with delete pipes with the B&W and air bags and his fits just like mine.
Old 02-21-2012, 08:09 AM
got what i need.
great info...thank you all.
Old 02-21-2012, 08:37 AM
A little off topic but do you still have your spare tire with your duals?
Sent from the mower shop
Old 02-21-2012, 05:37 PM
Yea still in there and it doesn't rub at all! I even have a 19.5 rim for a spare
