Dpf/Cat Delete ? - Ford Powerstroke Diesel Forum
Old 02-11-2012, 08:27 PM
Dpf/Cat Delete ?
I have a 09 Ford 6.4 with a bully dog triple dog gt tuner that does not support the dpf/cat delete i have already purchased the the delete pipe kit and would like to install it what are the side effects ill encounter besides the check engine light without buyng a different tuner and programming this mod out
Old 02-11-2012, 08:38 PM
Cant run without the dpf unless you having tunning to allow you to. I guess you can but you wont get very far.
Old 02-12-2012, 05:26 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
Your truck will go into limp mode if you delete the DPF with out proper tuning.
Old 02-13-2012, 09:35 AM
What they said. Mos of the time they wont even start once turned off and those codes are present.
Old 02-13-2012, 10:40 AM
So your saying that I don't need to program them out that once the codes come up the dpf wont even come on so Im good I just have to deal with the light being on
Old 02-13-2012, 11:12 AM
They r saying that your truck will not run without dpf removed supported tuning.
Bully dog + no dpf= no go. You need a h&s or spartan tuner.
Old 02-13-2012, 11:15 AM
if you delete the dpf with out a tuner that allows that. ex h&s and spartan does allow it. then your truck will not start or run at all. if the bullydog does nnot allow it then you have to get a h&s or spartan or sct that does allow it then you can delete it
