At what point is a wastegate needed? - Ford Powerstroke Diesel Forum
Old 02-07-2012, 03:30 PM
My truck is an 08 6.4 with the h&s, dpf and egr delete. I have the HD300 tune loaded and on wild I see a max boost psi of 42 and 55psi in exhaust
Back pressure. If I were to buy the WOP wastegate kit, what would be the highest I should see on ebp? Just wondering if it's worth the 800 right now? I rarely run it hard but when I do decide to play I want it to be safe
Old 02-07-2012, 05:47 PM
Send a message via AIM to maddenjr
Wondering myself i have been kicking this around alot lately esp after seeing these up pipe failures
Old 02-07-2012, 05:49 PM
Yeah my thoughts exactly. i dont want to have the cab pulled if im at my limit and need a wastegate to prevent this.
Old 02-07-2012, 06:19 PM
I was told by Rudys and Spartan that I dont need a wastegate at my level of mods, looking at what you have, you shouldnt need one either. If anything a BOV would be something to look at. I run 60-70 psi EBP so you are definately in the clear
Old 02-07-2012, 06:20 PM
Built54:
Only 42psi boost? Ive seen upwards of 52psi running spartans 275 tune at WOT.
Old 02-07-2012, 06:32 PM
Yeah seems like on my 275 tune i would see 45psi, but since i updated to the HD300 i show 42 max..?
Old 02-07-2012, 07:02 PM
I am also considering the same thing, but especially after Jeff's write up on the Elite turbo, I think I am just going to keep my eye on the EGB for now and wait until I save up enough for the turbo and studs and only pull the cab once.
Old 02-07-2012, 08:01 PM
curious why you recommend a blow off valve?
Old 02-08-2012, 12:33 PM
I would recommend a wastegate if you spray nitrous or have a fuel system setup that requires one. If the fuel system and turbo setup you have are sized correctly, a wastegate is not needed.
Bone stock trucks blow up-pipes, and back pressure is nowhere near as high on a stock truck as it is on a tuned truck.
Old 02-08-2012, 02:13 PM
So your saying I should save my money for now? Just trying to prevent any issues
