Egr as waste gate - Ford Powerstroke Diesel Forum
Old 02-06-2012, 06:57 AM
Egr as waste gate
Is there a reason why the egr can't be used as a waste gate? I know it's best get rid of them in stock form but with a set of bullet proof coolers and the right program could it be done?
Old 02-06-2012, 10:30 AM
If you are okay with your intake manifold getting gummed up with soot, it's possible. Back pressure is best controlled with the VGT turbo though.
Old 02-06-2012, 12:47 PM
I know it's best to get rid of them. The only reason I ask is because of all the recent post about waste gates, blown up pipes and turbo piping.
Old 02-06-2012, 01:23 PM
Stock trucks that cycle the EGR valve blow up-pipes. It's a known weak link on these trucks. Some trucks will have the issue, others won't.
Old 02-06-2012, 05:07 PM
So you don't want the egr valve to cycle period?
Sent from my DROID2 using Tapatalk
Old 02-06-2012, 10:55 PM
I personally do not. I don't have anything related to the EGR on my white truck. It's been removed for over a year now. My intake manifold is spotless. Can't say the same for one that sees valve cycle.
Old 02-07-2012, 04:35 AM
Send a message via AIM to Duffie112
Does the intake clear up after the delete if theres soot in there now? And do bulletproof coolers hurt the truck as much as stockers?
Old 02-07-2012, 05:20 AM
I think the only way to clean an intake manifold is to physically remove it and clean it. Between the EGR and the ccv it can get pretty nasty!
Old 02-07-2012, 06:37 AM
That would be correct.
