Turbo set up - Ford Powerstroke Diesel Forum
Old 02-03-2012, 06:31 PM
Turbo set up
I have an 08 6.4 and currently have the mods in my sig. this summer i am building my trans (suncoast rebuild kit, suncoast tc or the rcd one, and billit input shaft) and after that i plan on doing the industrial injection 85% over hpfp.
So i think i have the fuel side of things covered just wondering what you guys suggest for the turbo side of things. i work at GOS performance in montana and we dont have that much experience with 6.4's on the performance side of things.
I plan on making 700 hp fuel only with egts under controll. so what do you guys suggest for turbos? ive been thinking about the industrial compounds but dont know if they are quite enough.
Thanks in advance!!!
Old 02-03-2012, 06:51 PM
just subscribing. I read a thread recently about twisted diesel in VA building great transmissions. One cat said he wished he would have gotten a twisted trans before his suncoast. but just subbing to learn about turbo set ups on 6.4. Good luck.
Old 02-05-2012, 08:17 PM
Anyone at all have input? i dont wanna one of get eliete's set up's. does anyone else out there make a good set up thats not just moddified stocks?
Old 02-05-2012, 08:23 PM
Elite Tow Power compounds or Elite Tow Power X compounds.
Old 02-05-2012, 08:53 PM
im looking for options besides elite
Old 02-05-2012, 09:26 PM
I wouldn't limit myself to Industrial's modded stock turbos. I like Elite's turbo setups because they uses Precision Turbo wheels and turbos. I just installed their 71mm low pressure turbo. It's a modded stock low pressure that uses a 71mm billet Precision wheel. It's awesome. Elite's High Power turbos seem to be the perfect setup. 670 HP on stock fuel and 800 HP potential with added fuel. Great drivability and instant spool up.
Old 02-06-2012, 06:54 PM
What about running a single kit but making it a twin kit? I know the thread that WOP did on here mentioned that they where going to be making there kit so it could be set up as twin system?
I myself will only be upgrading my low pressure turbo when the time comes around.
Old 02-06-2012, 07:46 PM
I have thought about building my own set up. maybe a 62/80 and a s474 but i think i would rather not have my truck down for that long. and i would want to buy a set up that is known to work well on a 6.4
Old 02-06-2012, 10:53 PM
That would be Elite turbos....they are proven.
Old 03-26-2012, 07:48 PM
You might to reconsider the industrial injection 85% over hpfp. From what I understand, they are hit and miss but prone to expensive failures.
Jeff, do you agree?
