Custom Exhaust? - Ford Powerstroke Diesel Forum
Old 01-26-2012, 02:33 PM
Question Custom Exhaust?
Hi guys I just got an 08 f250 and I was wondering if its possible to mount a custom exhaust from the down pipe( thus deleting the dpf) and run a minimaxx or blackmaxx?
Also, how do I set the tuner to "do its thing" when I have the dpf out so its not in limp mode etc?
Old 01-26-2012, 03:39 PM
You can run any exaust of your choice, and any tuner that supports the dpf deletes.
Old 01-26-2012, 03:42 PM
You could fabricate a custom exhaust if you wanted to. Aftermarket exhaust kits are so cheap though its not really worth it unless you plan on doing something unconventional.
The tuner comes pre-loaded with DPF on or DPF off tunes. If you are ditching it, choose the the DPF off tunes. The tuner is very user friendly and easy to use.
Old 01-26-2012, 05:37 PM
Seems simple enough! Thanks guys
