Tuner and exaust ??? - Ford Powerstroke Diesel Forum
Old 01-26-2012, 06:03 AM
I have read both, that you need to order exaust with and without bungs, which is it, i will be getting 5" flo pro.
Also, i am going to run a mini maxx, does the mini come with a pyrometer connection, or is that extra,i have seen it both ways, not sure why it would be optional for the pyro. And doesnt the ford have a factory egt probe that the h&s connects to.
Old 01-26-2012, 06:27 AM
Depending on the tuner you get you will need or not need bungs. If your ordering a H&S MiniMax, you will not need bungs if it's brand new.
Unsure about your other questions so I'll let others chime in.
Old 01-26-2012, 06:34 AM
As stated above with the Mini Maxx you do not need bungs. I have the 4 inch flo pro straight pipe with an H&S Mini Maxx. And yes the Mini Maxx reads from Ford's factory egt probe so you do not need an extra probe.
Old 01-26-2012, 06:55 AM
Ditto what matt said.
Old 01-26-2012, 06:57 AM
So according to the above post
1. I can order a turbo back flo pro 5" WITH NO BUNGS.
2. I can order a mini maxx WITHOUT THE PYRO, is this correct?
Thanks guys.
Brian
Old 01-26-2012, 07:07 AM
From what I understand there is a factory post turbo egt sensor so u do not need the pyro.
Old 01-26-2012, 07:13 AM
I really want pre turbo temps, so do i need the tuner with the pyro.
Old 01-26-2012, 10:07 AM
The factory sensor is pre-turbo.
Old 01-26-2012, 10:36 AM
10-4 Thanks fellas. What is the reason for buying an exaust with bungs, if you are deleted.
Old 01-26-2012, 10:45 AM
If you ran an SCT tuner that deleted the DPF, you would need bungs for the exhaust sensors. With Spartan and H&S, you do not need the sensors.
