need a quick explanation from the gurus - EGR delete/wastegate - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 84 Old 01-23-2012, 11:23 AM Thread Starter
hello gentlemen, need some help that id greatly appreciate
im trying to help out my dad make a decision concerning his 08 6.4L
he currently has the spartan 275+ tune and an aftermarket exhaust (not sure which one) and ended up popping his head gasket.
hes having it fixed with new studs and while the cab is off his mechanic recomended he do an EGR delete with a wastegate. my research leads me to believe that the wastegate is to control high back pressures while the egr delete essentially deletes the egr coolers that are prone to failure on these trucks. the kit also included a staineless DP and blow off valve.
can someone tell me if i have the right idea? better yet, can someone summarize quickly what exactly these EGR delete/wastegate kits accomplish and if they are truly neccesary for longevity in higher HP applications.
thanks guys. i appreciate it.
whitetwinturbo is offline
post #2 of 84 Old 01-23-2012, 11:57 AM
44magnum's Avatar
From what I understand the wastegate is to make sure backpressure dosnt get to high on these high hp tunes. And yes the egr delete kit will completly delete the egr coolers. Necessary I dont know, but probably not a bad idea. Hopefully someone with more info will chime in.
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #3 of 84 Old 01-23-2012, 12:38 PM
If I remember correctly, the wastegate is for guys making serious power with serious pressure. if you are keeping the stock turbos I don't think you will run anything better than 40#. I BELIEVE (dont know for sure) the wastegate is for guys running huge single turbos making around 60# plus. Theory is 40 is safe and you will not make it with stock turbos. I hope a more knowledgeable and qualified person can chime in but this is my belief
Sent from my Autoguide iPad app
08 CC SB
Fun Stuff
Mini Max / S&B Intake / 4" MBRP DP / 5" MPRP DP Back / 5" x 6" x 18" MPRP BLACK Tip
Normal Stuff
10" shallow RF sub w/ custom box & amp rack / Xtant 600W amp / Tinted front windows to match factory rears / Recon bed lights
08SuperDiesel is offline
post #4 of 84 Old 01-23-2012, 01:00 PM Thread Starter
i had my dad call spartan and they pretty much said what u guys are saying. he confirmed it with one of the guys at Rivercity and it turns out he is going to go with a river city EGR delete w/intake pipe. no need for a wastegate.
post #5 of 84 Old 01-23-2012, 01:02 PM
Eric@PTP's Avatar
The waste gate helps with guys running the 250 and up hp tunes. The small exhaust housing on the high pressure VGT turbo causes a lot of back pressure, we have a kit that deletes all the egr equipment and also requires no welding or modification to the downpipe.
You can also add the polished stainless intake elbow to it as well.
EGRD64WG Wide Open Performance Wastegate/EGR Delete Kit 2008-10 Powerstroke 6.4L
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #6 of 84 Old 01-23-2012, 01:24 PM
Thero's Avatar
Eric, so are you saying that anyone running a tune above 250 should probably have a wastegated EGR delete, even with stock turbos? I'm currently running the Spartan 300 tune and will be deleting the EGR soon and just want to make sure. I was always under the impression that it wasn't necessary, but I'd rather error on the safe side if you know what I mean!!
__________________________________________
2008 F250 Lariat - CC / SB / 4x4
AFE Stage 2 Intake
Spartan (300EL DD)
AFE DP back 4" straight pipe w/ 6" tip
Originally Posted by XPLOSIV View Post
She finally gave it up after about 20 mins.
Thero is offline
post #7 of 84 Old 01-23-2012, 01:48 PM
Eric@PTP's Avatar
Well really the the stock turbos are the culprit of the high back pressure, the volume of exhaust the the 6.4 can put out cant get through the small exhaust housing on the vgt turbo fast enough with out causing an excess of pressure. That's why you see so many up pipe failures on the 6.4's. Its really not an issue as much with the aftermarket turbo guys unless they are spraying nitrous and need to keep peak boost in check, or if they are running anything that peaks at over 50-55 psi on stock head bolts.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #8 of 84 Old 01-23-2012, 02:02 PM
jmoore1225's Avatar
Stock turbos will certainly make more than 40lbs!!
jmoore1225 is offline
post #9 of 84 Old 01-23-2012, 02:20 PM
Eric@PTP's Avatar
Depending on the tune yes.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #10 of 84 Old 01-23-2012, 02:35 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
I was told by a reputable source you do not need a wastegate unless you are adding nitrous or propane and yes on my HD300 tune I can push well over 40lbs
strokinpower is offline
